harleykins's avatar
harleykins
R8000 not working at all
I purchase the Nighthawk R8000 Router almost a year and a half ago.  On Tuesday this week (the 14th), we started experiencing connectivity issues with the Wifi. Some of our devices were failing to connect, but we thought it was Comcast since there were some vans doing installation up the street.  Really didn't think too much of it since later that night it finally connected.  On Wednesday, not only did the wifi stop working, the router as a whole stopped working.  It was connected to the network, but I couldn't get to through the app on my phone or through the browser on my desktop.  I tried resetting it, but it looks like nothing happens.  The power light and the 2.4 ghz, 5ghz, USB 3.0 and 2.0 lights are lit, but that's all.  When I depress the reset button, I do not see the lights flash at all like the manual reads.  Does anyone have any ideas on how to reset the router or access it?  Or is it just completely dead?  Thank you.
  • JamesGL's avatar
    JamesGL
    Jul 06, 2016
    Hi Harleykins,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi harleykins,
    1. What is the color of the Internet light?
    2. Can you go online when your computer is directly connected to the modem?
    3. Press the reset button at the back of the router for 30 secs or until the power flashes orange.
    • harleykins's avatar
      harleykins
      Thanks for your reply!  There is no internet light.  I can access the internet just fine connected to my computer.  Because I'm a bit of a packrat, we're using our old router for our home and not having any issues with connectivity.  I've held the reset button for a few minutes and nothing happens, no lights flash.  They just stay lit to white.
      • JamesGL's avatar
        JamesGL
        Hi harleykins,
        1. When connected to the router, can you still get an IP address on your computer. If yes, what is the IP address? And can you ping the default gateway?
