MarkIndiana
Jun 08, 2017Aspirant
R8000 password does not protect
Hello,
Curious problem. Upon changing router password on my Nighthawk R8000, my tablet can still use two of the three icons to use the network. Powered off the tablet and brought it back up and it still connects to the network and has complete internet access. Only the Netgear65 was blocked by needing a new password to access the network. Did not have to put in the new password like I had to do with DTV genie, Laptops and smartphones. Why is it that my tablet was able to continue using the network and the online genie network map would show the tablet accessing the network...without needing to change to the CORRECT password? Using WPA2-PSK setting. Guest access is disabled. Furthermore, it does see the number of devices as correct which is 9 however, it doesn't show all devices???
Also, Network map does not show my daughters smartphone when it accesses the network yet, shows her sister's phone which is an identical make and model?
Thanks for any information...
This is the usual way of accessing your device.
Just point your browser at one of these addresses:
http://www.routerlogin.com/
or
http://www.routerlogin.net
If they don't work, then the IP address might be an option. Here the usual suspects are:
http://192.168.0.1
or
http://192.168.1.1
Check the manual, which you can get here:
R8000 | Product | Support | NETGEAR
This explains what to do.
- MarkIndianaAspirant
Okay, my tablet is a Samsung. Parent's tablet has the ability to do the same thing, their tablet is an LG. They are/were able to access the network without logging in. Is this a concern? Is the router protected? Is the network?
Thanks.
Did you change the PW for all wifi SSID names? Besure to try and forget or delete prior used profiles on your devices then set up the new connection again. Change the SSID name and PW on all radios to something unique between each radio so you know which one your connecting too.
Use WPA2 and AES only for best security.
Hmmm. No, I did not and that probably is the problem. I though quite simply that changing one changed all. I will do this immediately. Thank You!
MarkIndiana wrote:Hello,
The router password is not the same thing as the wifi password.
Are you sure you changed the right one?
