Beck73's avatar
Beck73
Tutor
Jan 15, 2021
R8000 Requiring weekly rebooting (help!)
Hello everyone. I just upgraded from a R6400 that we had for several years to a R8000 about a month ago. The R6400 in the whole time we had it was only rebooted when we were doing upgrades, no problems ever with it staying online.
Moving now to the R8000, we have been having to reboot the router at least once a week since switching to it. No rhyme or reason or specific time of it hanging up. It has become a pain as well with work and school (from home).
Anyone else had similar problems or suggestions?
The firmware we are currently running is v1.0.4.68
Edit: one important thing I forgot to mention. When it decides to have this little ‘hiccup’ issue often what will happen is the router will appear to disconnect devices. When we try to reconnect to the router (we can see its name clearly in the list to connect to) it will ask for the password for some reason and when you try typing it -
It will not accept it. The only way to get back in to the router/wifi is to reboot it at this point.
  • plemans's avatar
    What modem/gateway is it connected to?
    Did you ever try a factory reset and clean install (not from backup)?
    • Beck73's avatar
      Beck73
      Tutor
      I’m not sure I understand your first question. I have fiber via a local provider. It doesn’t require any sort of login. The fiber runs directly into the router via ethernet.
      As for your other suggestion, I had not tried that. I just attempted it a few minutes ago and reset the router (via the hole in the back) and went thru the process of redoing the settings.
      It seemed fine for about an hour - I had still been tweaking things then suddenly I could no longer refresh any pages. When I tried going to Google, I was dead in the water.
      I closed the browser and tried rejoining the network and got that same message as before asking for the password (getting it on all devices now) just like usual.
      Just for giggles I tried putting in the password that came with my router and it isn’t working either, prior to me changing it after resetting the router.
      • plemans's avatar
        Not being sarcastic but fibre doesn't turn into ethernet. There's some box the fibre is connected to that converts it to ethernet. Sometimes its a simple ont without an integrated router but sometimes it has its own routing features.
        Just trying to determine that.
