scardona007
Dec 16, 2016Follower
R8000 Security Vulnerability: VU#582384 but I have a 7900
I have a Nighthawk X6 R7900 and received an email from NetGear about updating the firmware but the email only mentioned the R8000. I understand the 7900 and 8000 are similar but not sure if I am also affected and should install. Anybody know? It sure would be nice if the email also stated R7900 if that is indeed also affected.
Thanks.
Please see the Security Advisory
The fix for the R7900 is in the R7900 beta firmware, so to get the fix you would need to update to that.
We already have an existing thread on this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Two-leading-Netgear-routers-are-vulnerable-to-a-severe-security/m-p/1185124#U1185124
Please continue the discussion there.
- UmrkTutorIt doesn't appear that the 7900 is affected, at least that's how I interpret the availability of a beta, rather than the tested, tried and true production version. But then again, I do not like uncertainty. Perhaps a Netgear rep can confirm the need to update the firmware for owners of the 7900, like scardona, me and others....
- mdgm-ntgrNETGEAR Employee Retired
- Retired_Member
I received the same email too and done some lookup. Here's the link to the R7900 patch. It is in Beta though.
http://kb.netgear.com/000036459/R7900-Firmware-Version-1-0-1-8-Beta
