NicoR
Aug 03, 2022Aspirant
R8000P Firmware Rollback
Hello,
I have been having issues with the internet connection on the PCs in the our households.
It always said when googling something that the website could not be reached and only after refreshing the page multiple times it worked.
So I searched up some stuff and also found that you should try to update your router´s firmware to an older version of it and see if it works.
That is what I tried to do but I forgot the answers to the Password Security Questions so I factory reseted the router and the questions and tried again but now when I answer the questions it still says that they are incorrect, so I can not login.
What can I do so the Security Questions work and that I can Rollback the firmware?
That sounds like bad advice. Where did you read it?
You would do better to start with your problem and look for solutions.
What makes you think that the router is involved? Any error messages or anything?
Which website "could not be reached"? One in particular? All websites?
Which browser? Have you tried a different browser?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
- billybob420Aspirant
Most likely this is the DNS issue introduced in some firmware revision over a year ago; I think it was version 1.0.4.76 (at least, that's the R8000 firmware version that broke DNS lookups about 50% of the time for me and many others), so rolling back to version 1.0.4.68 would most likely fix it. Netgear does not seem interested in fixing this absolutely broken firmware, so I'm personally using the Fresh Tomato firmware now as it actually works.
It's unfortunate how bad Netgear has gotten these days, will personally be grabbing an Asus router next time I upgrade.
Before rolling back the firmware, try enabling IPv6.
For a lot of people that helped fix the issue.
If that doesn't work, then I'd try the rollback
- NicoRAspirant
I am trying to rollback the firmware but when I get to the point where I have to answer the Security Questions it tells me that the answers are wrong and I already factory reset the router to confirm that the answers are right.
So I can not log into the admin manual.
What can I do to fix it with the Security Questions?
