QQ2222
Oct 31, 2021Aspirant
R8000P firmware update issue
I believe the router is compromised since it has been uploading 100GB data every day for past several days.
I was trying to upgrade firmware V1.4.1.50_1.3.10 to the latest one. But there seems no way to fix it by using all the methods i can find from this forum. I have spent hours but failed to upgrade it. Any update on this issue?
I'd start by changing your ssid/password.
Then slowly add devices back in.
You might be surprised at whats using data
- QQ2222Aspirant
I did everything you said. Still firmware wont update and DOS attack is happening. This is well know issue as discussed already on the forum. The only solution is replacement.
I sent you the mod's info on checking on the firmware.
But the removing device fix the data usage?
