notgoodatthis's avatar
Aug 25, 2022
R8000P Nighthawk Router is causing delay internet, but works great when connected direct to modem
I have my PC connect to my Nighthawk router with a LAN cable and my router is connected to my cable modem.  When I access any website there is about a second or so delay before it goes to the website.  If I'm in say my online banking and want to redirect to billpay it usually won't do it at all.  I use Quickbooks for work and if I try to do an online backup it always fails.
HOWEVER - if I unplug my pc from the Nighthawk and plug directly into the cable modem.....it always works.   What am I doing wrong?   Also, it didn't always use to do this.
  • FURRYe38's avatar
    Power OFF the ISP Modem for 1 minute then back ON. Then walk thru the set wizard using a wired PC and web browser at 192.168.1.1
  • FURRYe38's avatar
      • FURRYe38's avatar
        Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
        Is Armor, Circle, or Traffic Meter enabled or has those ever been enabled?
        Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
        Turn off and unplug modem.
        Turn on computers and rest of network.
