Javichu1984
Mar 09, 2016Aspirant
R8500 - Set up same SSID in 2,4Ghz and 5Ghz band
Hello everybody. I'm going to buy the new R8500, but before I wan't to know if now is possible to set up the same SSID in the 2,4Ghz and 5Ghz Band. I remember that in the past it was not possible...
- Mar 09, 2016
Yes you can set up all three radios to use the same SSID and passphrase. That's how I have mine configured. It's called "Load Balancing" in the router's manual. Alternatively, you can bind the pair of 5Ghz radios to a single 5Ghz SSID in what Netgear calls "Smart Connect", leaving you with the 2.4Ghz radio for legacy devices and the combined 5Ghz radios for the newer tech.
spewak
Mar 10, 2016Luminary
Javi,
Great question. I did not know that it was possible to have same SSID for both bands.
