camcar28
Jan 28, 2018Initiate
R8500 how to unlock wifi region
I've just unlocked a R8500 bought in US and now working in EU. You know that all the router wifi that are selled in US market have wifi region locked to United States or North America, but I've found...
- Jan 29, 2018
It's true ...you can use Telnet on WiFi but is safer to use a wired connection, by Telnet you can change many parameters and brick your router and the only way to recover your router is to use TFTP in a wired way.
antinode
Jan 28, 2018Guru
> [...] You should connect not in wifi but wired to your router [...]
Why? Does it actually matter?
> You should enable Telnet on your R8500 and the solution is
> http://routerlogin.net/debug and you check as active the Telnet check
> box.
Many router models don't have a "Telnet check box", but various
"Netgear Telnet Enable" programs are available on the 'net. (I use the
program which I modified, http://antinode.info/nte .)
> Step 4:
> Activate at prompt the Telnet
> Step 5:
> The first Telnet command is "open" "IP address" of your R8500 and user
> and password as usual I've not tried routerlogin.net but I suppose that
> is working
Save a step: telnet <address_or_name>
- camcar28Jan 29, 2018Initiate
