ericgarvin's avatar
ericgarvin
R8500 Nighthawk router not working
Having problems with network going down.  Current components are a cm600 modem, a 8500 router and a gs116 switch.  All netgear products.  I was watching hulu on an Apple Tv last night and the boys were on xbox's all hardwired.  Network has not changed configuration for 2 years since I bought the equipment.  The network suddenly went down.  Reset the network, network still didn't come back.  Called Comcast and they reset the modem from there network.  Still didn't fix the issue.  Went out the check the termination coming into the house.  looked fine.  Kinda frustrated.  Its out of warranty now.  Any help would be appreciated.
  • Yup I am back up. I just disconnected the whole lot and reset my network. I also realized that I had one cable creating a loop on the switch. I am confident that was really the problem. I must have done this after the original reset.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Any updates on your network is it back up?
    DarrenM
    • ericgarvin's avatar
      ericgarvin
      • myersw's avatar
        myersw
        Master
        ericgarvin
        Don't you hate it when you create your own problems? ;)
        Yes I suspect the loop you created was your network issue.
  • Normal first step would be to Ethernet attach PC in place of router and see if things worked then. If so then it has to do with the router, If not then you get to fight with the ISP.
