JoergA22's avatar
JoergA22
R8500 Nighthawk with Firmware V1.0.2.158 fails sending notification e-mail
My Nighthawk R8500 with firmware V1.0.2.158 has been configured to send notification e-mails, but it fails sending the mails.
Log-entry:  "[email failed] Bad sequence of commands, Saturday, May 14,2022 13:01:00"
Already check for newer firmware which fixes the problem - but no update available.
The SMTP-Mailserver requires authentication and TLS-encryption. Is this not supported by the R8500? Are there any restrictions for the password (though it is accepted ...)?
  • FURRYe38's avatar
    What Browser are you using?
    What email services are you using?
    How is the email server on the router configured? Auto or Specific port?
    Was a factory reset and setup from scratch performed after the FW was updated?
    "Already check for newer firmware which fixes the problem - but no update available." <No sure what this means here.
    • JoergA22's avatar
      JoergA22
      Thanks for taking your time to look into this problem.
      What browser do I use? => I'm using Microsoft Edge, today it's Version 101.0.1210.39, but sometimes I'm using Google Chrome.
      What email service do I use? => It's ionos.de, very common in Germany
      How is the email client on the router configured?
      - 2 Destination Mail-addresses (our mailbox for IT-services and additionally my personal mailbox)
      - the appropriate SMTP server (smtp.ionos.de)
      - Specific Port 587 (as required by the mail-server, not Auto-detect, though Auto-detect found this port too)
      - Mail server requires authentication
      - username and password as defined for the mail-account on the mail-server (a specific mail-account for the Nighthawk)
      Was a factory reset and setup from scratch performed after the FW was updated? => Yes, in fact, because a firmware-update was not possible without a factory reset
      "Already check for newer firmware which fixes the problem - but no update available." <No sure what this means here => I've checked whether the installed firmware is the latest version and verified that no newer version is available yet.
