ChrisRogers91
Feb 29, 2016Tutor
R8500 Reboot Loop
My R8500 seems to have crashed today, and is now stuck in a reboot loop. I was working (connected to the router via wifi), and the network dropped. I got up to see what the issue was and could see th...
- Mar 09, 2016FWIW, when the support team contacted me (OP), they said it was a hardware issue, and shipped me a new unit (just arrived today).
Best,
Chris
VE6CGX
Mar 01, 2016Master
You can try this. Power off router. Leave it for 5 mins. or so. Then holding the reset button down, power up.
Wait until power light flashes then let go of the reset button. Now does it finish rebooting? Can you ping the
router? Then what is TTL time value?
