ChrisRogers91
Feb 29, 2016Tutor
R8500 Reboot Loop
My R8500 seems to have crashed today, and is now stuck in a reboot loop. I was working (connected to the router via wifi), and the network dropped. I got up to see what the issue was and could see th...
- Mar 09, 2016FWIW, when the support team contacted me (OP), they said it was a hardware issue, and shipped me a new unit (just arrived today).
Best,
Chris
ChrisRogers91
Mar 03, 2016Tutor
Hey,
Thanks for the tip, but holding the reset button while booting doesn't seem to do anything.
If I set my computer up with a static ip, I can ping the router part way through the boot process. TTL is 100. Here's a sample of the ping output:
From 192.168.1.75 icmp_seq=744 Destination Host Unreachable From 192.168.1.75 icmp_seq=745 Destination Host Unreachable 64 bytes from 192.168.1.1: icmp_seq=746 ttl=100 time=3007 ms 64 bytes from 192.168.1.1: icmp_seq=747 ttl=100 time=1999 ms 64 bytes from 192.168.1.1: icmp_seq=749 ttl=100 time=1.69 ms 64 bytes from 192.168.1.1: icmp_seq=750 ttl=100 time=1.65 ms 64 bytes from 192.168.1.1: icmp_seq=751 ttl=100 time=1.67 ms 64 bytes from 192.168.1.1: icmp_seq=752 ttl=100 time=1.70 ms From 192.168.1.75 icmp_seq=785 Destination Host Unreachable From 192.168.1.75 icmp_seq=786 Destination Host Unreachable
Best,
Chris
VE6CGX
Mar 03, 2016Master
TTL=100ms means it is waiting for firmware. You have to use TFTP method to reload firmware. You may have to try few time
to be successful. Don't forget to enable tftp service on your Windows PC
