ChrisRogers91
Feb 29, 2016Tutor
R8500 Reboot Loop
My R8500 seems to have crashed today, and is now stuck in a reboot loop. I was working (connected to the router via wifi), and the network dropped. I got up to see what the issue was and could see th...
- Mar 09, 2016FWIW, when the support team contacted me (OP), they said it was a hardware issue, and shipped me a new unit (just arrived today).
Best,
Chris
ChrisRogers91
Mar 09, 2016Tutor
Best,
Chris
Best,
Chris
- rlaroch1Mar 09, 2016Guide
Best,
ChrisLucky you. I bought this device as is with known issues so I can only dream. It's worse than I expected but I'm determined to find a way. #fun
I wonder if the boot loader is ok since pressing the reset button doesn't trigger the recovery mode...
Maybe if I try loading an open source firmware that matches the file type already in mine it'll work. Last I knew dd-wrt didn't have one for an R8500.
