ChrisRogers91
Feb 29, 2016Tutor
R8500 Reboot Loop
My R8500 seems to have crashed today, and is now stuck in a reboot loop. I was working (connected to the router via wifi), and the network dropped. I got up to see what the issue was and could see th...
- Mar 09, 2016FWIW, when the support team contacted me (OP), they said it was a hardware issue, and shipped me a new unit (just arrived today).
Best,
Chris
pablocr
Mar 16, 2016Aspirant
Just got this router only changed the SSID via the app and now its in a reboot loop, reset does not work, is there an article or phone number to permanently fix this?
rlaroch1
Mar 16, 2016Guide
I wish I knew the answer to that. Sounds like it's in the same exact condition as mine. I even hooked up the serial interface, invoked a blinking amber power light (restore mode) tried to tftpd the firmware with puTTY and that - sadly - didn't work. Somehow it doesn't seem right that such an expensive product would so easily brick!!!!!
- ElaineMMar 23, 2016NETGEAR Employee Retired
pablocr Kindly register your router and submit an open case.
