chascent's avatar
chascent
Luminary
Nov 12, 2016
R8500-V1.0.2.80_1.0.71 - Port 68 shows closed NOT Stealth
Here we go again. I just got around to checking this and sure enough the Port 68 closed problem
is back! I will not use a firmware that does not stealth ALL my ports.
Went back to DDWRT and ALL ports are STEALTH. Why can't Netgear get this right?
CC
  • chascent's avatar
    chascent
    Nov 18, 2016
    I reset modem, reflashed firmware, reset again then manually put in my settings.
    No ALL Stealth.
    CC
  • Retired_Member's avatar
    Retired_Member
    What are you using to scan the ports. My port 68 is stealth as are the rest.
    • chascent's avatar
      chascent
      Luminary
      Shields up. Port 68 is Blue all others are green.
      I install DDWRT and everything is stealth. Why is this? Its not my ISP for sure.
      CC
