chascent
Nov 12, 2016Luminary
R8500-V1.0.2.80_1.0.71 - Port 68 shows closed NOT Stealth
Here we go again. I just got around to checking this and sure enough the Port 68 closed problem
is back! I will not use a firmware that does not stealth ALL my ports.
Went back to DDWRT and ALL ports are STEALTH. Why can't Netgear get this right?
CC
I reset modem, reflashed firmware, reset again then manually put in my settings.
No ALL Stealth.
CC
- Retired_Member
What are you using to scan the ports. My port 68 is stealth as are the rest.
- chascentLuminary
Shields up. Port 68 is Blue all others are green.
I install DDWRT and everything is stealth. Why is this? Its not my ISP for sure.
CC
- Retired_Member
