Ra-Dzik's avatar
Ra-Dzik
Apprentice
May 26, 2021
R9000 - problem with VPN IPSec
Hello,
after the firmware upgrade (to version 1.0.5.28) I observe problem with connection through VPN IPSec (Cisco AnyConnect).
After several hours of work, I cannot connect via VPN. A reset of the router helps and I can log in again via VPN.
Previously, the problem did not occur with an earlier firmware version.
Please help me to solve the problem.
  • plemans's avatar
    here's the order i'd try.
    1. factory reset the router and reinstall. Sometimes old settings cause issues.
    2. reinstall the firmware. maybe something didn't install correct and is corrupt.
    3. downgrade the firmware. maybe it did introduce a bug.
    • Ra-Dzik's avatar
      Ra-Dzik
      Apprentice
      Are you writing seriously?!
      Factory reset and setting up all settings and computers from scratch is a half day job!
      This is not a solution to my problem :-(
      • plemans's avatar
        Ra-Dzik wrote:
        Are you writing seriously?!----didn't you post on here? So I'm writing to respond.
        Factory reset and setting up all settings and computers from scratch is a half day job!----then maybe simplifying your setup or how you're doing it is in order if its taking you a half a day to install a router.
        This is not a solution to my problem :-(-----Ok, do you see a giant "fix it" button on it? No? I dont' either. There are no simple "click this" and its fixed buttons.
