Nuforce
Nov 20, 2023Aspirant
R9000 Nighthawk X10 Router SFP internet port question
Hi
I want to be able to use the X10 as a bridge to connect to my existing wireless network. I also want to connect a device I have to the router via the SFP port.
Will the SFP port output access to the internet for the connected device if I do this?
Also, if I connect other devices to the other ethernet ports on the x10, will the devices see each other, with one connected via SFP and the others in the RJ45 ports?
Thanks
I've not tried this with mine however I presume it should be enabled and work while in wireless brige mode. Something to try if you have a SFP to ethernet adapter plugged in while in wireless bridge mode and see.
I'd set up the router with a ethernet connection to one of the regular LAN Ports first, then test after that.
Yes, this is named as Access Point mode. How do I change my NETGEAR router to AP mode?
I think he wants to configure the router for wireless bridge mode...and act as a wireless client then connect a wired PC to the SPF port using a SFP to ethernet converter...
There is no wireless client mode available on most (if not all, the exception are few vey old models) Netgear Routers allow to make it a wireless bridge member.
