LukeBAus's avatar
Jan 26, 2022
R9000 No Ethernet Connectivity
Hi All,
Recently in the last few weeks I upgraded to firmware V1.0.5.38 and I for some reason my devices connected via a wired connection drop out after a short amount of time and I need to reboot the router to get the connectivity back. all the link lights are showing activity but there seems to be an issue and I am not sure what it is.
I have downgraded back to V1.0.5.36 but I am still having the same issue.
My PC states the connection is established but to an unidentified network. Once I restart it has connectivity to the internet via this wired connection instead of the wireless connection. When the wired connection drops out it goes back to the wireless connection.
Any thoughts would be greatly appreciated.
Wireless connectivity is never affected.
Thanks,
Luke
  • LukeBAus's avatar
    LukeBAus
    Jan 30, 2022
    So issue was I had a device connected that was doing some kind of broadcast somehow and took down all wired devices!
    Previously this device was in a connected state and configured, I recently done a factory reset on it and it was attached and not configured.
    Anyhoo all good now! Thanks for the support all.
  • plemans's avatar
    whenever you have issues after a firmware change, the first step is usually a factory reset. Sometimes old/bad settings can cause issues.
    Have you tried this?
    • LukeBAus's avatar
      LukeBAus
      Tutor
      Thanks for the reply! Was trying to avoid it but will give it a go :-)
      • LukeBAus's avatar
        LukeBAus
        Tutor
        Same problem after the factory reset :-( everything on ethernet stops responding after a few minutes
    • LukeBAus's avatar
      LukeBAus
      Tutor
      • michaelkenward's avatar
        michaelkenward
        Ouch. Nice work, Sherlock.
        Was this something that anyone else is likely to come across?
