kwhit13's avatar
kwhit13
Tutor
Dec 26, 2016
R9000 Plex Media Server Problem
I am having problems with setting up plex.  I orginally tried to enable Plex with my USB WD My book attached however it never displayed the drive so I figured there was a problem.  I removed the driv...
  • kwhit13's avatar
    kwhit13
    Feb 17, 2017
    Ok, after many conversations with technical support I believe my problems are resolved.  The problem it turned out to be the Titles of my partitions I had on my hard drive.  If you have an & symbol Plex will not recognize anything (literally one title with the & symbol and Plex will not recognize any hard drives), however, readyshare has no problem with it.  I ended up finding this out on my own by reformatting and naming it a basic name and confirmed it when I tested a title with the & symbol.  I have been running it now for about 2 weeks and no problems.
