kwhit13
Dec 26, 2016Tutor
R9000 Plex Media Server Problem
I am having problems with setting up plex. I orginally tried to enable Plex with my USB WD My book attached however it never displayed the drive so I figured there was a problem. I removed the driv...
- Feb 17, 2017
Ok, after many conversations with technical support I believe my problems are resolved. The problem it turned out to be the Titles of my partitions I had on my hard drive. If you have an & symbol Plex will not recognize anything (literally one title with the & symbol and Plex will not recognize any hard drives), however, readyshare has no problem with it. I ended up finding this out on my own by reformatting and naming it a basic name and confirmed it when I tested a title with the & symbol. I have been running it now for about 2 weeks and no problems.
JamesGL
Dec 28, 2016NETGEAR Employee Retired
Hi kwhit13,
1. Can you see the drive under ReadyShare when you connect it to the router?
2. If yes, follow the steps given on the KB below.
https://kb.netgear.com/31247/How-do-I-set-up-my-Plex-Media-Server-on-my-Nighthawk-X10-R9000-router
JamesGL
Community Team
kwhit13
Jan 02, 2017Tutor
Ok so I have tried a few things and it actually created another problem that completely seperate.
First I factory reset my router and in a nutshell I still can't do anything with Plex. I no longer get the error of the USB device not being there but it lets me enable with no errors or anything however I never see status or a USB device on the Plex page (it's blank). The 4TB USB My Book is hooked up to the USB port on the router and the readyshare portion sees all the partitions just fine.
New problem....after I reset the router I can no longer log into the router using my main PC (I have been using it up until this point). The Genie app opens and sees everything as good but if I try to do any admin actions it won't let me into the router. The Chrome browser will not let me in, the browser says connection reset error. I've tried routerlogin.net, routerlogin.com, and 192.168.1.1...all the same. I cleared all the browser history (deleted everything) and have restarted the computer and still can't login. I can get on the WiFi and surf the internet, I can also ping the router just fine through CMD Prompt. I was able to log into the router with my laptop just fine and I configured the router but my main PC still can't log into the router.
I really need some help and this is getting frustrating. I still am having issue running the VPN service but that can wait until I can resolve these 2 issues.
- JamesGLJan 03, 2017NETGEAR Employee Retired
Hi kwhit13,
I would suggest you to contact support team in order to properly address your concern. The device is still new and still within support warranty.
- ElaineMFeb 16, 2017NETGEAR Employee Retired
kwhit13 Are you still having problems with your Plex? Make sure that you have the latest Plex version installed by checking the box "Enable Automatic PLEX New Version Update"
- kwhit13Feb 17, 2017Tutor
