eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
reeper
Jun 05, 2014Aspirant
I was having disconnects for 4 weeks at least twice a day, Thought it was the nighthawk r7000 but it turned out to be my Netgear DG834GT modem that probably could not handle the speed tried all sorts r7000 kong ddrwt put it in modem only mode still disconnected.
Hooked up a very old thomson speedtouch 546v6 I had lying around all sorted not 1 freeze or disconnect in last 4 days :) love the r7000 blazing fast.
ElaineM
May 13, 2016NETGEAR Employee Retired
For those who have R7000, kindly try to use the beta fw 1.0.5.62.
- trevordixonMay 14, 2016Aspirant
I'm using V1.0.6.28_1.1.83 and experiencing random internet disconnects a few times a day. This problem started a couple weeks ago. 1.0.5.62 sounds like a downgrade from 1.0.6. Am I misunderstanding the meaning of these version strings? Would you recommend I try switching to this beta 1.0.5.62 if my current firmware seems higher than that?
- IrvSpMay 14, 2016Master
Yes, it IS a downgrade. NG pulled all V1.0.5 and V1.0.6 beta F/W as they gave a lot of people problems. Stablized the code and removed Arlo support and re-issued it as V1.0.5.60 and now the new one at https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/m-p/1078114#M31145. After you install the beta RESET the router and MANUALLY re-enter the settings. Should solve your problem possibly.
