eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
RogerSC
Feb 21, 2014Virtuoso
aeg4373 wrote: Tried the latest FW 1.0.3 issued a couple days ago and that was by far the worst - wouldn't stay connected to the internet for more than 30 seconds before disconnecting, then reconnecting. Hopefully netgear gets their act together on this.
If you're doing factory default reset after each upgrade, and manually re-entering your configuration, I'd suggest going to my.netgear.com and opening an issue with Netgear there. There's something about your particular network that the Netgear firmware isn't dealing with, apparently. I think that your experience, especially with the new firmware, is pretty unusual, so if you want to get Netgear to look at your problems, my advice would be to report them.
If Netgear doesn't know about your problems, no way that they're going to get their act together on them. They may not anyways, but it's worth a try.
If you've already reported this, never mind *smile*.
