eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
cowboychincs
Feb 27, 2014Tutor
Dear Devor... thanks... guess you just like to have someone run around and find the user manual... huh? Why couldn't you have just stated what MTU stood for and then provided the following:
4. Select ADVANCED > Setup > WAN Setup.
5. In the MTU Size field, enter a value from 64 to 1500.
6. Click the Apply button.
Guess that would not have been as easy... right?:rolleyes:
Not sure what this has to do with the R7000 dropping all internet connections, wired and wireless... was this a suggested fix by a Netgear Tech, or something else? Just curious as to how you stumbled onto this or if it was a Netgear suggested fix....
