eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
aeg4373
Mar 01, 2014Aspirant
Thanks Roger SC - I did the factory default reset before each upgrade as you suggested. You must do a factory default reset after each upgrade, and manually re-entering your configuration. I am currently running the latest firmware and it is has been pretty stable since then. I am not sure why all the times I talked to netgear support that they did not mention this as a potential issue.
