eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
Devor
Mar 01, 2014Luminary
It's one of the first things mentioned in the release notes. You may be surprised to know how many people there are that don't read the release notes or find it too much trouble to read the user manual.
If it's any consolation, I've seen many issues get blamed on new firmware that turn out to be nothing more than the firmware getting improperly changed. Changing the firmware properly squarely points to a firmware issue. You might want to look at the link in my signature, see step 4. Although written for a different model, the Guide provides one way to properly change firmware and might just save you some grief. Additionally, it might be beneficial to safely unplug any USB attached devices before changing the firmware and don't use saved configuration files between different firmware versions.
Congratulations on getting the issue sorted.
