eoz
Feb 07, 2014Follower
Random disconnects.
I bought an R7000 about a week ago now. My other router kept going wonky on me, could not take any load for any amount of time and was generally a miserable experience. Now, for my problem with th...
Devor
Mar 06, 2014Luminary
Or, you could contact your ISP (or look on their website) and find out what value to use for the MTU. If after setting the correct MTU there is still an issue, then you would know that the ISP needs to roll a truck to fix their equipment. Setting it unnecessarily low will degrade performance.
