moyers
Dec 25, 2015Aspirant
Range Reduction on Nighthawk R7000 – Part 2
Hello, I've had the Nighthawk R7000 for about 1 year now and it has performed with excellence. Within the past month however I've noticed a very weak wireless signal when moving far away from the...
- Retired_MemberDec 26, 2015
"The strange part is that only the 2.4 GHZ channel is experiencing these glitches"
The router has TWO distinct radios, One of them appears to be failing. Try re-installing FW and or factory reset, try switching the antennas around ( one may damaged ) All this should be done with extender turned OFF.
Retired_Member
Dec 26, 2015"The strange part is that only the 2.4 GHZ channel is experiencing these glitches"
moyers
Dec 30, 2015Aspirant
switching the antennas did the trick...appreciate!
