cordomite's avatar
cordomite
RAX70 Cannot Configure
Trying to configure my new Nighthawk not having much luck. I am trying to use it as my second Router. Changed the IP ranges to different ranges of my current router but it goes back to the default range each time I restart the new router. Connecting LAN-LAN from previous router shows no Internet. So I connected LAN-WAN and this time the Internet Setup Wizard got the Internet going and all was good for a while but now no Internet and I cannot even get back to the Router Page on 192.168.1.1. Sure would like to know what is going on here.
  • While I lost the internet a quick ipconfig showed an Internet address of 169.254.128.211 which explains the Internet loss but what happened to the 192.168.1.x Router assigned IP? I did ensure I pickep the Forware Update before as well.
  • plemans's avatar
    Whats the first router?
    have you setup the 2nd one you're attaching (the RAX) in access point mode?
    Disconnect it from the primary, reboot the RAX and then when you connect your computer to it, open a command prompt and type "ipconfig"  The default gateway should be the rax's ip address. Use that to access it and put it in access point modem. Then connect it to your primary router. Use the primary routers lan port to connect to the RAX's WAN port.
    • cordomite's avatar
      cordomite
      Hi, The first Router is a tp-link AX5400 VX420-G2V. Sorry but how to put the RAX into AP Mode? Also do I need to run the Internet Setup Wizard after I connect the LAN-WAN Cable to RAX?
      So far it has been running OK today I mean DHCP has not dropped on me like last nite and gave me an APIPA. The RAX decided to setup on a 191.168.0.1 network although I initially changed it to match my AX5400 network but with different DHCP ranges that did not seem to take.
      The AX5400 is on a 192.168.1.1 and interestingly enough I can talk to the AX5400 network from the RAX network but not the other way around. If I try to ping 192.168.0.1 from AX5400 it gets a reply from a 10.20.x.x address and "Destination net unreachable" message. I am thinking some static routes required to push through the other direction or the Windows Bitdefender to blame? Thanks.
        cordomite
        OK I switched the RAX to AP mode and now I can get to my main router with 192.168.0.1 but I don't know the IP of the RAX in AP Mode. If I disconnect all ports from the RAX and hookup a Laptop to a port, ipconfig shows me a 169.254 address. Does AP mode switch off the DHCP on the RAX? So how to get to the Router login on the RAX now?
