golways
Aug 27, 2021Aspirant
RAXE500 - Using 6 Ghz wifi network in France
Hi all,
I bought my RAXE500 router in May in the USA and use it in FRANCE. It works fine, except wifi 6 Ghz band.
Right now, the wifi 6 Ghz network is invisible to my Samsung Galaxy S21 Ultra and my Samsung QE65QN900ATXXC TV, whereas both devices are Wifi 6E certified.
WIFI 6E is now officially authorized in Europe and France since June 2021. Is there a way for me to activate the 6 Ghz network ? By installing a new firmware for example ? ;)
I would be happy to become a Netgear beta-tester to test such a new firmware that activates 6 Ghz network in France, if useful.
Thank you very much in advance for your help.
Franck
It might be approved but not sure if its made it into the firmware changes yet. There's usually a lag between approval and firmware changes.
Does it work if you change the region to a not france region?
(just to test)
maybe Altsai has an idea if its going to be released for france region
