Gini
Jan 06, 2016Aspirant
New router and effect of changing security setting from WPA to WPA2
I am planning on upgrading our old router, and I'm seriously considering the Nighthawk AC R7000. When I do so, I plan to also upgrade our present WiFi security from WPA to the Nighthawk's default, WP...
- Jan 06, 2016
Unless it is pretty old, it should support WPA2. In the devices wireless settings it should have the option to select the encryption, and you can see if it is in the list.
rpoffen
Jan 06, 2016Virtuoso
Gini
I don't even recall seeing encryption choices for things like my Kindles, tablets, Roku, etc., but I did find the R7000 manual online which said the default protocol was WPA-PSK [TKIP] + WPA2PSK [AES}. That's supposed to handle older devices, too, even if that choice isn't quite as secure as just WPA2. Thanks for the help!
- rpoffenJan 07, 2016Virtuoso
I think it is pretty safe to say that all smart phones, kindles, tablets, etc. support WPA2.
But setting mixed mode should be fine, the older protocols are less secure, but it takes more specialized equipment to break them, and your average hacker isn't going to go through all the neighborhoods scouring all the WiFi's looking for one to break into.
