crisismanager
Jun 10, 2017Aspirant
R7000 Wi-Fi speed dropped off 300%
I have the luxury of a fiber optic connection which gives me almost 1000 Mbps up and down hard-wired and which WAS giving me around 400 Mbps up/down wireless as well, but now it's down to around 100M...
- Jun 15, 2017
I appreciate the question, but already solved my problem. Didn't realize that I was, by default, logging into the slower 2.4 network and it has a 5.0 as well.
VE6CGX
Jun 10, 2017Master
Did you reboot the router and see? All your WiFi security setting is latest WPA2-AES(TKIP)? Is there any change in signal lelvel from router?
- crisismanagerJun 10, 2017Aspirant
Yes to rebooting the router (hard restart) and modem, no change. I don't know how to determine if it has the latest security setting, although I also installed the lastest firmware as part of my troubleshooting. And how do I measure signal level from the router? I'm an expert computer user - but not a techie, so baby terms would be appreciated! :-)
- JamesGLJun 14, 2017NETGEAR Employee Retired
Hi crisismanager,
What is the firmware version of the router?
Is it on both 2.4Ghz and 5Ghz?
What is the link rate of your devices?
- crisismanagerJun 15, 2017Aspirant
