agnj
Mar 01, 2018Aspirant
R9000 problem - Cannot connect network drive located on a Mac for use in Plex
Hello. I have successfully set up a new R9000 router. I am unable to connect a shared network drive for use in Plex. I am able to successfully connect a shared drive located on a PC running Win7, but ...
- Mar 07, 2018
I can't see the pictures...yet...I guess they have to be authorized by NetGear first - so when I can I'll be able to confirm your settings.
I'm on 10.13.4 at the moment and that's working for me. Could be that there is an issue with 10.13.3 and it will be fixed in the 10.13.4 release.
I'm wondering if this could be down to signing being enforced from the Mac, I have this disabled on the mahine I was connecting to as it caused varioous slowdowns when accessing a QNAP NAS, albeit fine when accessing Windows 2016 shares, which still was confirmed to use sharing.
https://support.apple.com/en-gb/HT205926
Pay attention to the 2nd part of the article, "Turn off packet signing on a macOS computer that hosts SMB shares"
Case850 - No need to be so abrasive. You obviously don't understand macs and the security laters in the OS - High Sierra has changed things and SMB is far more secure than Sierra (for example), some of the apple forums have recommended downgrading the OS where a Windows 2008 server or XP/Vista machine has been unable to connect, and this has worked - personally I think this to be a signing/encryption enforcment issue.
xnsys
Mar 07, 2018Luminary
Case850. Ah ha, you're not fully understading the OP's issue, it's not the mac connecting to the ReadyShare - Share, but the R9000 connecting to a share on the Mac via the Plex interface - there is an option in there to add a "Network Drive Connection from Local Network for the Plex Media Library"
@agnj - is the error you're getting "Your router can't connect to your network drive because of network errors." - I've just tried re-enabling signing on the Mac and that's the error I'm now getting - so looks like signing is the issue when accessing shares on the mac from the Plex interface.
@Case850 - Yes, the R9000 has had issues and things haven't worked properly since dxay one, but the latest firmware seems to have fixed a few issues along the way, although there are still several niggling little things that need to be resolved.
agnj
Mar 07, 2018Aspirant
xnsys = Boss
It was the packet signing issue! I followed the suggestion in the Apple KB article and it now works! Netgear must have tested it with older flavors of MacOS, but the newer SMB security settings are not compatible with the router out of the box. Hopefully, they will address it on an update. For now, this is a usable workaround since my clients and server are all on the same secure network.
Thanks very much for your suggestions and for working this out with me!
