Totti
Feb 20, 2014Aspirant
Wake On Lan with R7000
Hi, i get my new R7000 today and have an Asus RT-N66U before. The Asus WOL work fine but i found no way to use WOL with the R7000. With the R7000 i cant use 255.255.255.255 as Subnetmask to use ...
- Aug 10, 2015
Hi Riker.
Now that I've confirmed that the removal of my solution was a moderation, I'll try repeating it from memory (I was actually using this thread, bookmarked, to remember how to do it).
- Download TelnetEnable from here: https://github.com/LuKePicci/NetgearTelnetEnable/blob/master/binaries/windows/telnetenable.exe?raw=true
- Open a DoS/Command Prompt on a PC directly connected to the same LAN and type 'telnetenable.exe <router-IP> <router-MAC> admin <admin-password>'
- Telnet to the router
- Type 'arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm' where x.x.x.x is the WoL destination IP address (not .255) and mm... is
the WoL destination's MAC address
You should then have a static ARP entry in your router. Set up forwarding of port 9/UDP to your device you want to wake and it should work.
- Dave
millertime23
Sep 23, 2015Aspirant
I was worried that might be the case. Maybe a workaround would be to write a .bat file that will execute in windows task scheduler
millertime23
Sep 24, 2015Aspirant
I wrote up a visual basic script that can be executed in windows task scheduler (ie once a day, every PC start, once a week, etc). It may be handy in the event of a power loss or router reboot. You can also save this script anywhere on your pc and with one click have your ARP entries restored. Copy and paste the code below. Edit it with your IP addresses and MAC addresses (per ViperGeek's instructions), then save it as "whatever.vbs"
Option Explicit
On Error Resume Next
Dim WshShell
set WshShell=CreateObject("WScript.Shell")
WshShell.run "cmd.exe"
WScript.Sleep 1000
WshShell.Sendkeys "telnetenable.exe 192.168.1.1 ROUTERMACADDRESS admin routerpassword{ENTER}"
WScript.Sleep 1000
WshShell.SendKeys "telnet 192.168.1.1{ENTER}"
WScript.Sleep 1000
WshShell.SendKeys "arp -i br0 -s x.x.x.x mm:mm:mm:mm:mm:mm where x.x.x.x is the WoL destination IP address (not .255) and mm... is the WoL destination's MAC address{ENTER}"
WScript.Sleep 2000
WshShell.SendKeys "arp{ENTER}"
WScript.Sleep 3000
WshShell.SendKeys "exit{ENTER}"
WScript.Sleep 1000
WScript.QuitThe last "arp{ENTER}" command is optional. I just added that and a 3 second delay to verify the "PERM" entry was successful
