Valek
Oct 09, 2013Aspirant
Xbox Optimized QOS
According to the description of the R7000 it has optimized QOS for Xbox and I read a review that mentioned that Netgear worked with Microsoft to get the best optimization possible for gaming and the n...
- Oct 10, 2013Okay.... have to understand port forwarding XBOX and QoS/Prioritization are 2 separate configurations. Port forwarding configurations allows you to enter XBOX live and use the Mic for voice. QoS/Prioritization then sets the XBOX as the HIGHEST priority so it will receive the most bandwidth for lag free gaming!!!! Over someone else who is on YOUR network surfing the web and possibly streaming youtube or buying stuff on Amazon!!!!!! Your XBOX will take priority over all of that!!! Here is the Port forwarding config. If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your PC or Xbox 360 console to communicate with Xbox Live. This configuration change is sometimes called “opening ports” or "port forwarding." Xbox Live requires the following ports to be open: Port 88 (UDP) Port 3074 (UDP and TCP) Port 53 (UDP and TCP) Port 80 (TCP)
NUKLRSOLDR
Jan 04, 2015Guide
If you look at the default qos rules, xbox is only set to high while a handful of other things are set to highest. I recommend deleting all defaults and setting up a custom rule to your xbox mac address and set to highest priority.
