unkerjay
Mar 25, 2017Aspirant
readyshare mount error(13): Permission denied
I'm using Linux Mint 18.1 Mate. This WAS working. Used: sudo mount -t cifs //###.###.###.###/USB_storage /media/public -o sec=ntlm Prompted for password and I'm in. That's NOT WORKING anymor...
- Mar 28, 2017
Ok, I've tried recommendations from the sidebar (excepting those for Windows as noted). I've tried what I've found on the web.
And I've tried shumaku's recommendations.
NOTHING has made a difference.
So, I've connected it to a remote laptop and will access it from there when I remote connect to that laptop.Either that or I may try USB over IP on a raspberry pi I've got set up in another room.
Readyshare works great, when it works.
Thanx
unkerjay
I checked my permissions.
I reset them using:
sudo chmod -R 777
I then went in and tried modifying files and I double checked that the permissions settings
matched the chmod.
Check on all counts.
I checked the permissions and chmod on the folder to which I was assigning the networked drive.
Check.
So, I'm running out of locations for checking the appropriate permissions. Something I missed?
(Apparently.) What?
- unkerjayMar 25, 2017Aspirant
P.S. I'm here to try to solve a problem. Not to win a popularity contest. So, all the notifications to my ego
aren't working. And this probably won't help.
Just saying.
