unkerjay
Mar 25, 2017Aspirant
readyshare mount error(13): Permission denied
I'm using Linux Mint 18.1 Mate. This WAS working. Used: sudo mount -t cifs //###.###.###.###/USB_storage /media/public -o sec=ntlm Prompted for password and I'm in. That's NOT WORKING anymor...
- Mar 28, 2017
Ok, I've tried recommendations from the sidebar (excepting those for Windows as noted). I've tried what I've found on the web.
And I've tried shumaku's recommendations.
NOTHING has made a difference.
So, I've connected it to a remote laptop and will access it from there when I remote connect to that laptop.Either that or I may try USB over IP on a raspberry pi I've got set up in another room.
Readyshare works great, when it works.
Thanx
unkerjay
Mar 28, 2017Aspirant
Thanx
schumaku
Mar 29, 2017Guru - Experienced User
The ReadSHARE is a plain simple (and outdated, vulnerable, ...) SAMBA 3.0.24 serving SMB 1.0 protocol, and max ntlm auth security on all Nighthawk routers.
Well, I'm still convinced it's either a problem between keyboard and chair, or a problem with your Linux distro, the SAMBA Kernel module in place, the SAMBA utilities in place, ..
- unkerjayMar 29, 2017Aspirant
That and a dime, along with all the other recommendations not fixing the problem.
There's a number of places this problem (and its solution) could be hiding.
My goal was to be able to access the data remotely.I've accomplished that. Just no longer through ReadyShare.
USB over IP, as I've read has it's problems too.
But, remote access to the PC to which the drive is connected is working.
I can continue to attempt to resolve the problem through ReadyShare, through
Linux config.Or, I can go with what works.
Sometimes life is too short.
