Retired_Member's avatar
Retired_Member
Oct 18, 2016
Readyshare not working in AP mode
Hello,
because i am using my r7500 as a ''second'' router i put it in AP mode.
after i did readyshare stopt working !! is it not possible to use readyshare in AP mode ??
that whould be a major let down !!
  • Retired_Member's avatar
    Retired_Member
    Nov 10, 2016
    apparently after you put it in AP mode you need to ''restart'' the router before you can acces Readyshare.
    after i powerd off my router and turned it back on everything worked just fine :smileyembarrassed:
    feel so stupid right now....... such a simple ''fix''
    thanks for all the help and quick responses tho !! :heart:
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi Retired_Member
    Welcome to the community!
    How do you access ReadySHARE? Is it through wired or wireless computer?
    Are you using R7500v1?
    I have the setup right now and I can still access the ReadySHARE through a computer that's connected behind the R7500v1 using \\readyshare\USB_Storage
      Retired_Member
      Hello,
      sorry for the delay, but i had givvin up.
      i will try it now again, i am accesing readyshare wired and wireless ( both not working )
      when i get the router back out of AP everything works again.
      i have the R7500 V1
        Retired_Member
        Netgear genie doesnt see my HDD anymore aswell
