dwturner's avatar
dwturner
Readyshare USB stopped working after update to Firmware V1.0.5.70
I updated the Firmware to V1.0.5.70 and my Readyshare USB function stopped working.  It has been set up and working fine for several years until this update. I have tried 12 different USB flash drive...
  • JamesGL's avatar
    JamesGL
    Oct 27, 2016
    Hi PetrSvarc,
    Reset the router to factory default and manually reconfigure the device. Check if the USB drive is being detected. Check as well if the drive is working if connected to the computer.
    JamesGL
    Community Team
