dwturner
Jul 19, 2016Aspirant
Readyshare USB stopped working after update to Firmware V1.0.5.70
I updated the Firmware to V1.0.5.70 and my Readyshare USB function stopped working. It has been set up and working fine for several years until this update. I have tried 12 different USB flash drive...
- Oct 27, 2016
Hi PetrSvarc,
Reset the router to factory default and manually reconfigure the device. Check if the USB drive is being detected. Check as well if the drive is working if connected to the computer.
JamesGL
Community Team
dwturner
Jul 25, 2016Aspirant
The model of the product is R7000 (AC1900 smart wifi router), I thought I had marked it in the tags.
Thanks
Dave
JamesGL
Jul 26, 2016NETGEAR Employee Retired
Hi dwturner,
Reset the router to factory default and manually reconfigure the device. Check again the ReadyShare after the reset if it is already working.
JamesGL
Community Team
