dwturner
Jul 19, 2016Aspirant
Readyshare USB stopped working after update to Firmware V1.0.5.70
I updated the Firmware to V1.0.5.70 and my Readyshare USB function stopped working. It has been set up and working fine for several years until this update. I have tried 12 different USB flash drive...
- Oct 27, 2016
Hi PetrSvarc,
Reset the router to factory default and manually reconfigure the device. Check if the USB drive is being detected. Check as well if the drive is working if connected to the computer.
JamesGL
Community Team
PetrSvarc
Oct 27, 2016Aspirant
After update to firmware V1.0.7.2_1.1.93, USB3.0 stoped working with ICYBOX IB -RD3620SU3.
I know that Netgear has the list with approved external disks and boxes, But this box has worked!!! Can you fix it Netgear, please ? Thank you
JamesGL
Oct 27, 2016NETGEAR Employee Retired
Hi PetrSvarc,
JamesGL
Community Team
