Rene-de-Ruyter
Jun 27, 2017Aspirant
ReadyShare Vault: No readyshare device detected
Hi all, I have a problem with accessing the readyshare drive in ReadyShare Vault. In fact it doesn't present itself at all. But..., The connected USB drives ARE available and accessable under...
- Jul 31, 2017
Hi Elaine,
I went one version back and it all worked!
I then went to the latest FW version and it still seems to work.
No clue why, but happy.
ElaineM
Jul 18, 2017NETGEAR Employee Retired
Can you try to use a different computer to isolate?
On the other PC can you totally uninstall any firewall installed?
For the router, can you downgrade the firmware and see if it will show the correct statistics.
Rene-de-Ruyter
Jul 31, 2017Aspirant
Hi Elaine,
- ElaineMAug 01, 2017NETGEAR Employee Retired
That's strange! But that's good news, it's working now.
Thank you for the update!
