OldBob
May 08, 2025Luminary
Replacement for R7960 router
I have never been able to update the Nighthawk R7960 router firmware and it seems this model does have an issue with this function and the work around is beyond my abilities. I cannot use the iPhon...
May 08, 2025Guru - Experienced User
There is a workaround to fix the firmware issue.
R8000P V1.4.1.50 Update workaround | NETGEAR Communities
If its beyond your abilities, nothing wrong with the firmware you were on.
