Issachunt's avatar
Issachunt
Follower
Dec 29, 2022
Replacement Router for BT Smart Hub 2
Hi looking for a a replacement router to replace the BT Smart hub 2...any suggestions please?
Router is FTTP Smart Hub
Thank you
  • michaelkenward's avatar
    michaelkenward
    What sort if cinnection do you get to the BT Smart hub?
    BT Smart Hub 2 | BT Help
    If you have an Optical Network Terminator (ONT) you can buy whatever router you like. Pick one that meets your needs and fits your budget.
    Try plugging your needs into the filters on the product pages:
    Wireless Routers for Home | NETGEAR
    and
    Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
    Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
  • FURRYe38's avatar
    I would also contact the ISP to check to see what they support officially on there network and if there are any requirements.
    Thank you
      michaelkenward
      That's not how BT works. It wouldn't know a router from its elbow.
