PMoonchild's avatar
PMoonchild
Follower
Feb 15, 2021
Reset Button
re new Nighthawk D7000
Problem 1
It arrived yesterday. Was setting it up with my internet provider. There was a problem so she asked me to reset it.
I tried & tried but it appears to not be working at all....ie it doesn't depress....lights don't change or blink....firstly used the little tool that comes with Apple phones & then a large paper clip.  It arrived all packaged in a box. Could it simply be broken
Problem 2
To get around this I went to do a firmware upgrade because an update was showing on the Netgear website.  I tried it on 2 different laptops in two different browsers.  It just appeared to be jammed on a message that was flickering & says firmware was downloading.  Again no lights blinking....and I left it doing this for 20 minutes and there was no change
Can anyone help? It would be so challenging if I have to return it bc it's faulty.....I need it for my work...
can
  • > re new Nighthawk D7000
       D7000[v1] or D7000v2?  Look for "Model" on the product label.
    Firmware version?  Connected to what?
    > [...] it doesn't depress [...]
       There should be a little movement (less than a mm?) with a little
    detent/click.  No significant force is needed.
    > [...] lights don't change or blink [...]
       I'd expect an immediate change to the Power indicator, with more
    flashing stuff after 5-10 seconds.
    > [...] It arrived all packaged in a box. Could it simply be broken
       Ask the seller?  Anything _could_ be broken.  Someone could have
    shoved a suitable punch into the hole, hard, and wrecked the
    (non-very-strong) switch.
    > [...] I tried it on 2 different laptops [...]
       "tried it" how, exactly?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Downloads.  (For older versions, under Firmware and
    Software Downloads, look for "View Previous Versions".)  Find the
    kit(s).  Download the kit(s) you want.  Read the "Release Notes" file
    for instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
    When that fails because of a deficient User Manual, try:
       https://kb.netgear.com/23960
       If you can get logged into the thing with a web browser, then there
    might be a non-mechanical control at ADVANCED > Administration > Backup
    Settings : Revert to factory default settings.
  • michaelkenward's avatar
    michaelkenward
    Is this "Netgear website" the support pages for your device? Or was that a message in an app or interface?
    A manual update is usually better than anything over wifi or any automated process.
    How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
    Which ISP is this? You might also find guidance on how to set up with them around here. But you'll have more luck tracking down messages about the D7000 – the hardware version isn't usually that important as long as you get the correct firmware for your device – in the right section.
    DSL Modems & Routers
    • antinode's avatar
      antinode
      Guru
      > [...] the hardware version isn't usually that important as long as you
      > get the correct firmware for your device [...]
         I'm curious.  How, exactly, do you expect anyone to "get the correct
      firmware for your device" without knowing which "hardware version" is
      involved?
      > [...] in the right section.
         Because the forum section is the most important detail about which to
      worry?  Yow.
