OBoy
Jul 10, 2021Tutor
reset remote
Trying to reset router remotely.
I have password but when I enter admin and the password it takes me to a screen asking for the router serial number not to a reset option.
I dont have the serial # at remote site to enter.
Help please.
- DarrenMSr. NETGEAR Moderator
Have you tried using the Nighthawk app?
DarrenM
- OBoyTutor
when I use app on my phone on T-Mobil it says R7000 Disconnected and list serial #
"Trying" _how_, exactly? Why? Did it stop working properly?
> [...] when I enter admin and the password it takes me to a screen
> asking for the router serial number not to a reset option."enter admin and the password" into _what_? What, exactly, are you
doing, from what, where, connected to what, how?Generally, these routers ask for a serial number as part of a
password-recovery scheme (which does not always work). Which suggests
that you're providing a bad password.
> when I use app on my phone [...]Have you used "app" successfully before?
