Tek4Seth's avatar
Dec 13, 2021
Router configuration
Hi,
My network looks like this for the moment:
- a router (connected to the fiber)
- my Netgear router connects to the other router on the WAN port
But I would like to access the whole network; and especially let the Netgear router manage what it manages for the moment (dhcp, rules, etc ...)
I would like to be able, from the PCs connected to the Netgear, to access the PCs connected to the other router.
is it possible?
thanks in advance
      • plemans's avatar
        Tek4Seth wrote:
        so this is not possible?
        Whats not possible? Getting them all on the same network?
        Sure it is. You just need to only have 1 router actually managing the routing part of it. So if the netgear is what you're connecting as the 2nd router, put it in access point mode.
