meezy
Jul 22, 2017Aspirant
Router connects to the internet, but as soon as I connect any device is disconnects
Hello. I am having a frustrating time setting up my router. One day my old router died, it was a WNR2000, I couldn't get an internet signal or anything. So I decided to upgrade and buy the r7000. ...
- Jul 30, 2017
Problem solved.. I took the router back and got a Linksys. Come to find out Nighthawk routers do not work with Vivints technology.
JamesGL
Jul 26, 2017NETGEAR Employee Retired
Hi meezy,
Did the WNR2000 have the same setup as the R7000?
What is the firmware version of the router?
meezy
Jul 27, 2017Aspirant
As far as I can tell all the settings that were on the old router are the exact same as the new r7000 router. The only difference is this ready share thing that I have nothing in to share. I've even tried using the old routers MAC address on the new router with no luck.
