Tamumiket's avatar
Tamumiket
Router does not support https protocol R9000 Nighthawk
Some time after I purchased the R9000 router the https protocol stopped being supported and I may only access the admin interface via http
Are there any suggestions to restore https access to the admin interface.
I have been updating the f/w but I haven’t received any updates in the last 2 years
thank you
  • michaelkenward's avatar
    michaelkenward
    That's how it works  by default. Why do you want https?
    If you insist, try here:
    • Advanced
    • Advanced setup
    • Web Service Management
    Be prepared for it to break things.
    • microchip8's avatar
      microchip8
      Master
      HTTPS for your private LAN is useless, unless you don't trust your own network.
    • Tamumiket's avatar
      Tamumiket
      Thank you for the prompt reply!
      http is not encrypted so the login passwords are sent clear text. Someone already logged in the WiFi can intercept these packets
      I cannot see the web services option. Have they stopped updating the OS for this router ?
        microchip8
        Master
        Enabling HTTPS on the router does not mean it's globally available to the LAN/WiFi. It's only for the router's web interface so login credentials are encrypted.
